2 members (KEVINSKI, 55shaker),
125
Mod | | | Forums66 Topics128,187 Posts1,057,313 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | I have heard that a classic volkswagen product can change 6volts to 12 volts(inverter) in order to run 12v items(radio, stereo) but staying with the traditional 6v for the vehicle. Has anyone seen this or have done this
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Voltage booseter cubes are sold by most of the vendors and online at a bunch of sites. Usually run about a hundred bucks. I've been using one to power my Sony 12v radio and 12v tach for about six years.
DG
Denny G Sandwich, IL
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | im with denny, im running a sony plus some other low draw devices. this is where i got mine. http://www.halonmarketing.com/mall/Accessories.phpactually i have one of each. dont buy the hidden antenna. they work like a vacuum cleaner! i have blown the fuse once while rockin on down the road with the WHO. so either turn it down or carry spare fuses  | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Here's one with a little more "oomph"? As with the other style, there is a 6v + or - ground to 12v - ground version available. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | tim, thats the one i want to get. chief miles (oldgmctruck) has this one. it can be customed made to application. i could of used it on the south bend run last year. im hoping to have it for springfield this year  | | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | Thanks for all the ideas, now I have more info to investigate with. good luck with everything
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | Would any of these inverters be good to run a 12v wiper conversion?
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | no, these are for only light loads. the little one comes with a 6 amp fuse. ive blown it with the stereo. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Lets correct this since it seems to be an on-going thread, an inverter is an electrical device that converts direct current (DC) to alternating current (AC).
What we are dealing with here is simply a DC voltage booster to kick the 6v up to 12v. One of the small cubes has been powering my Sun Pro Tach and Sony CDX GT420U AM/FM/Compact Disc player for five or six years now and I’ve never blown a fuse. Although the radio is capable of 52w x4 I’m not trying to drive a four component speaker system with that much power. I found a pair of cheap 10 or 15w speakers that will slip in the door that supply plenty of volume. I’ve got no problem hearing talk radio, the oldies stations or big band music from a CD while I‘m cruising down the road at speed.
But I agree it won’t supply enough power to drive a wiper or heater motor and if you were trying to drive some big honkin‘ 100w speakers you would no doubt be blowing fuses with it.
Denny Graham Sandwich, IL
| | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | thanks to all the ideas, however I have found a posting that lead to Newport Engineering that advertises a booster to handle the load of a wiper, for those that are interested here is the link http://newportwipers.com/
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Good link for someone wanting a higher output converter. I find it interesting how they call it an "inverter" in the title but the description correctly calls it a "converter".
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | and for those who want an "OEM" solution, see here  Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks, Bill Do you know if that was a kit with a part number?
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Piggy-back dual generators. That's simply awesome. Well, not simple I guess. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no idea about the availability of the parts Tim, I just have that booklet saved for the diagrams and lists - note also that there's some early "AC generator" [alternator] info in it [1958] including a Delco 6V alternator  Chris - having the circuit diagrams with it does make it fairly simple, just be a chore to fab the mounting hardware, a good Denny job  I've been considering adding a 2nd alternator to my bus, just need to have it switchable so it isn't robbing HP when not needed Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Denny,
If you make the 6v/12v mounting hardware, I'd be please to test it out on my COE.
