7 members (Joe H, JW51, Millenimech, dt235sd, Eisenholtz, klhansen, Ponchogl), 109 guests, and 0 robots.
Topics128,051
Posts1,055,764
#821974 02/01/2012 9:34 PM
che
Offline
i bought a new ammeter and hooked it up per the wiring diagram: battery to the charging side of the guage; negative side of the guage to the voltage regulator. with the engine turned off, when i turn on the headlights, the ammeter shows that it's charging. shouldn't it be discharging? is the fix simply to reverse the wires? if so, why would the diagram have it backwards. this is a negative ground, 12 v, 1950 chevy half ton. thank you.
Che
1950 Chevy 3100
Riding in the Passing Lane
Reverse the wires. The current is flowing from the reg. to the bat. when it is cherging. There for it hiiks to the charge side. Did the ammeter show discharge when it was running?
1972 Chevy c10 Cheyenne Super
che
Offline
thanks for your reply. i'm not to the point where i can start the engine so i don't know the answer to your question.
Che
1950 Chevy 3100
