Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (jmoore, frogfarmer, Jon G), 105 guests, and 4 robots.
Topics128,288
Posts1,058,574
Members48,492
This is a follow along to my last question…not sure I ask the right question. I have a new to me “1946 3/4t Chevy PU”…it came to me with the 6volt battery using a negative ground strap going to starter. What do I need to check to make sure there is no damage being done to the electric circuit? Not sure why it was done.
John Kully
Ex Hall Monitor
Ex Hall Monitor
If you are asking if it's ok to use the starter housing as the battery ground the answer is yes. I ground my '38 on the starter housing.
You should also have a ground going from the motor to the frame and cab.
Are there any other issues (if any) with changing to a negative ground?
jkully.
You are changing from a positive ground to a negative ground?
In your first post, should we interpret that the cable from the negative post on your battery was attached to the starter switch/button on the body of the starter?
Should not bother a thing. DC motors do not care about line polarity. To reverse them you must change the armature current or the field (s) currents. The one exception is permanent magnet DC.
Light bulbs wont care either - no they will not become black holes.
Bonding the battery (aka grounding) to the starter makes a lot of sense and reduces resistance.
Dan Bentler
The one thing that will care if you change the polarity of your ground is the amp meter. It will read backwards. Simple fix though, just reverse the leads.
Kurt
If you reverse the polarity on a coil contrary to what it should be it will loose about 20 0/0 of its output.The post on the coil going to the dist must be the same as the batt term that is grounded.
