3 members (Naturalthud, Southerntruck, Peggy M), 285 guests, and 0 robots.
Topics128,080
Posts1,056,062
Members48,433
#821448 01/31/2012 7:06 AM
My 1950 AD 1/2 ton, are the brake lines 1/4" or 3/16"
rc356s #821645 01/31/2012 10:37 PM
Brake lines on my '50 truck were 1/4" when I bought it.
I changed them to 3/16" when I redid the brakes.
Do you know if the threaded fittings are the same for either 1/4" or 3/16"? Was there a reason why you change to 3/16"?
rc356s #821830 02/01/2012 10:55 AM
The threaded fittings on these trucks with the 1/4" hard lines are 7/16" x 24 TPI (Threads Per Inch).
I bought some fittings with the same thread for 3/16" hard lines by mail order from a supplier in PA. Ordinarily, the fittings for 3/16" brake pipework would be 3/8" x 24 TPI.
I used 3/16" pipework because it is so much easier to bend and install. Also 3/16" corrosion resistant Cupro Nickel brake pipe is much easier to get hold of here in the UK than similar 1/4" brake pipe.
I have been told that the reason 1/4" hard lines were originally used was that they would require fewer retaining clips than 3/16" pipework. I used lots of clips along the chassis when I reworked the brakes; I wouldn't want to risk a pipe failure resulting from vibration on any rigid pipework -especially the brakes.
