4 members (32Fordpuchoptop, 55shaker, TUTS 59, 1 invisible), 70 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
Junior Member
Junior Member
Installed one on my 54 3100 with Saginaw 4 speed and open driveline this weekend. What a difference! The PO had installed a HURST shifter but the stick was too short, shifts were sloppy and regularly got stuck in 2nd gear. After weeks of trying to fix the old one that was also too close to the seat, I ordered one from Patricks. Still a Hurst Competition shifter but with custom mounting plate (I had to do a little grinding to make it fit just right) and a long stick. Now the stick is right by my side,in the middle of the floor where it should be, shifts clean (I can use all four speed wahoo) and is much more pleasant to drive. Thanks to everyone in this forum I was able to research the kit and a number of 4 speed issues before settling on the Patricks product.
Bob McDuffee, co-host
DogWatch Cigar Radio
A podcast for and about cigars
www.dogwatchsocialclub.com
Thanks for posting this. I'm planning to drop in a 4 speed saginaw when I put in my 302. How does the shifter fit in relation to the cab? Does it match up with the original shifter location of an SM420?
Could you post or email me a picture?
Paint & Body Shop moderator
Junior Member
Junior Member
The kit moves the stick forward and to the right so it is right over where I believe the original would have been. It is in a very comfortable spot for driving, not a reach and the extra long shift stick is nice.
It moves it forward about 5 inches from where it would be with out the kit, which is right in front of the seat.
I had one in my 52.......it was sweet, just barely had to bump it.. the only problem I had was that I was always re-tightening the bolts to the shifter..the po had installed it... but it sure did shift good.
Redryder pix
My Hotrod
I also had this shifter on my '51 1/2 PU...I had no end of problems with the linkage locking up from 2nd to 3rd. Replaced linkage twice and even had a Hurst tech rep reinstall and adjust the linkage. The linkage set-up is very sensitve to vibration/wear and requires frequent readjustment. Further,you have to make sure your engine mounts are not worn and are secure as any torquing of the motor in its mounts will impact the the very close tolerances of this linkage.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
