3 members (Patharr, KEVINSKI, 1 invisible), 236 guests, and 2 robots.
Topics128,108
Posts1,056,230
Members48,436
#820724 01/29/2012 6:42 AM
V
V Offline
Could someone tell me how to remove the front main cap from a 1957 235.
The engine is still in the car. I've taken both bolts out and the two small bolts that go into the front plate. I've really put some pressure on this cap and it seems very stuck, as though there could be more bolts or something I don't know about.
Brandon
Take a plastic hammer and tap on the side while attenpting to rock it back and forth. There are no other bolts holding it on.
1951 1 Ton Completed
I like to use a large tapered punch, maybe a foot long or more, insert it into one of the bolt holes, and rock it forward and back. The cap will move, but it's a struggle sometimes!
V
V Offline
The engine is still in the car, so it's hard to get anything with proper leverage in there to work it out.
I was considering just leaving it, even though 2 of the 3 bearings I've taken off so far have been bad. I guess the smart thing to do is find a way to get in there and get the sucker off now that I know there aren't any more bolts anywhere.
Thanks for the responses,
Brandon
There was most likely gasket cement used on the timing plate gasket, which covers the front face of the front bearing cap, when assembled. They can be stuck pretty good.
My Blog
You might want to check that the bottom two bolts of the timeing cover isn't holding it.Larry
58 gmc 100 with 350 sbc
Try warming up the lower part of the timing cover flange with a propane torch. if gasket sealer is the problem, that might soften it up enough to help it release its hold on the cap.
V
V Offline
Thanks guys I got it off today. I made a tool out of a broken bolt and a steel mailbox post.
[IMG]http://i156.photobucket.com/albums/t24/vetteman61/Picture012.jpg[/IMG]
[IMG]http://i156.photobucket.com/albums/t24/vetteman61/Picture013-1.jpg[/IMG]
[IMG]http://i156.photobucket.com/albums/t24/vetteman61/Picture014.jpg[/IMG]
I now have a question about the blue gasket behind the main cap, but I'll post that as a new thread to not confuse the two topics.
Brandon
