3 members (NH46COE, Hotrod Lincoln, 1 invisible), 111 guests, and 8 robots.
Topics128,077
Posts1,056,031
Members48,433
#820912 01/29/2012 9:41 PM
Guys I am rehanging my running boards in 49 burb. I had to take front hangers off to put in the clip and need some help in determining correct position. The back two hangers on both sides were bent from years of abuse but I have retweaked them back to fit the running board bolt position (BFH and cable puller smile Do I line up the bottom edge of the runnning board with front an back fender bottom edge? When I do this the gap looks correct but one of my middle hangers is low by inch or more. Has it be been abused also. If anyone can direct me to some pictures it would be apppreciated.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
Guys I think I answered my own question by looking at Patrick Plummers great build pictures. Thanks Patrick and great job on your burb. So now question is what is approximate gap between front fender and front of running board?
Leo Offline
Moderator
Moderator
My gap between fender and running board is not the same on each side and I don't know why that turned out like that. On the driver's side, I have about 1/2" clearance while the passenger side is about 1/16". The gaps are very small at the back of the running boards.
1953panel
Thanks mine aren't the same either and that's why I posted. Mine are larger than your but I guess when they built these it didn't matter. Thanks for the reply.
I just want to make sure that you're aware that those rear brackets are slightly 'tweaked' from the factory, but if you are lining them up with the running board brackets, you should be fine.
I had quite a time aligning all of my metal on the truck in general. I started with the body 'loose' and aligned the front clip. Then, I hung my rear fenders and running boards and moved the entire body accordingly to ensure proper side to side gap on rear fenders, then I tighten body and split the difference in gaps with the front end and tightened. Then, I adjusted rear fenders, tightened, and played with the running boards and fenders for quite some time. I have a 1/4 in gap between fenders and rear of running board, and I'm going to live with that. I haven't bolted the fenders to the running board because I'd stress the metal more than I would want. I'm not sure if that was the right way, but most of the other panels line up just fine.
