2 members (Gray_Ghost, Joe W),
211
Mod | | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 24 New Guy | | New Guy Joined: Jan 2012 Posts: 24 | Forgive me if I missed it in the search feature but I'm looking for a diagram for the fuse panel in my 59 apache. Thank you.
59 Apache Long Fleetside 4x4 Big Back Window 53 Chevy 3/4 ton Longbox 63 Chevy Shortbox 64 Chevy Longbox 4x4 71 AM General Deuce and a half M109A3 84 Chevy Blazer M1009 Diesel 83 GMC 3/4 ton 4x4
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | what do you mean by 'diagram'? are you looking for what circuits are on it or where the various wires go? if the 59 is like my 56 (and i suspect it is), the fuse panel was optional to run accessories, so what circuits/wiring you have depends on what accessories your truck had originally and what might have been added over the last 50 years... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what tom says, but if you have an original fuse panel in the truck, the fuses are labeled, pretty easy to figure where the wires should go, and the 'basics' are shown as dotted lines labeled ACC JCT BLOCK on the wiring diagram in the shop manual, Bill | | | | | Joined: Jan 2012 Posts: 24 New Guy | | New Guy Joined: Jan 2012 Posts: 24 | what do you mean by 'diagram'? are you looking for what circuits are on it or where the various wires go? if the 59 is like my 56 (and i suspect it is), the fuse panel was optional to run accessories, so what circuits/wiring you have depends on what accessories your truck had originally and what might have been added over the last 50 years... The fuses are all labeled but there are a few wires with spade connectors that go on the outside edges of the fusebox. Someone unplugged all these and I was curious where they go back? Also found a makeshift "fuse" made out of 3 pennies! Not sure of the concept behind this but it wasn't touching but the top contacts Only the original engineer of this fuse will know it's intentions! LOL
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | which "outside edges"? - the one top left corner is power to the whole works, the other 'edges' are to individual items as labeled ... you'll need to trace those loose wires back to the other end to figure which fuse they go to Bill | | | | | Joined: Jan 2012 Posts: 24 New Guy | | New Guy Joined: Jan 2012 Posts: 24 | Thanks Bill, that answers my question. It is the terminals down the right side of your photo. All the wiring in this thing is complete and unhacked so I'm going to clean up the fuse box contacts and put it all back together. Thank you for the photo.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | couple fuses there are "extra", no telling what they might be to, but the center tab will be the 'hot' for the 2 fuses that supply the other 2 tabs - the top one "ACC LP" with 4 connections will be things like fog lamps or a spot light, or the glove box light
Bill | | | | | Joined: Jan 2012 Posts: 24 New Guy | | New Guy Joined: Jan 2012 Posts: 24 | Thanks again Bill, this has been a great help!
