Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (55shaker, 78buckshot, TrknGMC, Joe H, Gdads51, 1 invisible), 94 guests, and 4 robots.
Topics128,274
Posts1,058,436
Members48,490
#820557 01/28/2012 8:17 PM
Work on my doors continues: I ordered a door bumper kit. It arrived with 3 pairs of them and the are all different. I would like to know where they go, because i didn't find it in either the assembly manual nor shop manual.
here are the 3 kinds:
1) a 'large' one, about the size and shape of a gumdrop (sort of a flattened cone shape 1/2" in diameter, 1/2" tall). i think this goes on the cab in the upper corner at the back of the door opening.
2) a 'flat' one, about the diameter of a nickel, but 1/4" thick. i think this goes on the forward edge of the door up by the vent window.
3) a 'smaller' one, also conical in shape, but somewhat smaller than #1 above. not sure where this one goes, maybe on the door at the lower bottom?
Any light you could shed on this would be great. thanks!
you've got it exactly
thanks - a little deduction and luck!
