| | | Forums66 Topics128,012 Posts1,055,316 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2011 Posts: 39 | I have a 66' L60 and I have figured out that I have a T-170 rear axle but I cant find anyway to tell what the front is. It seems there are 4 different options f-050, f-070, f-090 and f-110 but I cant find anywhere that lists any specs or how to identify them. Is there a marking somewhere I'm not finding or is there a chart I can use to help match it? | | | | | Joined: Dec 2002 Posts: 2,548 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,548 | What's the gvw of your LCF. On todays trucks the gvw rating is the combined weight of the front & rear axle ratings. Example, if the truck has a 17500lb. rated rear axle, & a 7000lb. rated front axle, the gvw of the truck would be 24500lb. Seems like it's the same with older trucks also. When I had my LCF's, seems like my 1964 L60H had a 7000lb. front axle, & my '65 L80, had a 11000lb. front axle. | | |
