5 members (Wally / Montana, cmayna, UtahYork, Bill Hanlon, TexasA&M48Truck), 131 guests, and 2 robots.
Topics128,197
Posts1,057,259
Members48,466
Does anyone have a connecting rod from the pedal to the pivot that is left over from an engine upgrade? I am looking for a Advance Design model. The one I have has been altered and seems to be too short. If I can at lesast get a overall length dimesion would help if I have to stretch the one I have.
Thanks...
What year engine? There were at least two lengths, depending on the year. The pivot-post on the block for the bell-crank are in different locations.
1950 Truck
1959 235 L6
Your 59 engine will have the pivot point located in the forward location. The second location is further back on the block. You should be able to unscrew the pivot rod and install it in the rear location, I would think. Maybe some one else can answer the question for sure.
58' 3200 235 3-speed/OD
