4 members (Hotrod Lincoln, baldeagle, Joe H, Bill Hanlon), 112 guests, and 4 robots.
Topics128,014
Posts1,055,333
Members48,419
#819711 01/26/2012 12:27 AM
ceg
Offline
Anyone know of a "source: for a nos spindle for a 1950 chevy 1/2 ton? Mine is worn and the new bushings are loose in the spindle. Any one try oversize bushings?
Restoring 1950, 5 window, 1/2 ton, in family since new. Never done one before.
ceg #819716 01/26/2012 12:39 AM
Stock bushings are also almost loose in the spindle, they float on both inside and outside.
Not saying yourself aren't worn but many folks assume the bushings should have a press fit in these 1/2 ton spindles like about all other kingpin type front axles for years and years..
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #819843 01/26/2012 6:48 AM
I would be curious to know if the bearing surfaces of the spindle have excessive wear as well, mine were not in good shape after weeks of searching on-line and asking around I took the suggestion to have them hard chromed. I gave the shop the new bearings so that they could machine to a nice fit. Just a thought.
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
Grigg #819886 01/26/2012 3:07 PM
ceg
Offline
Mine will fall through the spindle. The assembly had noticible play before I took it apart. I understood the bushing are press fitted into the spindle with light pressure. Anyway I think they are too loose. As an alternativr to a new spindle, I am looking for oversized bushings as a solution, then machine the spindle for them.
ceg #819922 01/26/2012 4:28 PM
Originally Posted by ceg
...I understood the bushing are press fitted into the spindle with light pressure. ...
Yours may still be worn out...
But I'm trying to tell you they were never a press fit from the start, just a slip fit, the bushings float in the spindle and on the pin.
Some more threads covering your options of
-find new or used spindles
-machine oversize bushings
-fix bushings in spindle with Loctite 660
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=815002
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=732207
Grigg
---All pictures---
