| | | Forums66 Topics128,035 Posts1,055,441 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 30 New Guy | | New Guy Joined: Nov 2010 Posts: 30 | Anyone know of a "source: for a nos spindle for a 1950 chevy 1/2 ton? Mine is worn and the new bushings are loose in the spindle. Any one try oversize bushings?
Restoring 1950, 5 window, 1/2 ton, in family since new. Never done one before.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Stock bushings are also almost loose in the spindle, they float on both inside and outside. Not saying yourself aren't worn but many folks assume the bushings should have a press fit in these 1/2 ton spindles like about all other kingpin type front axles for years and years.. | | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | I would be curious to know if the bearing surfaces of the spindle have excessive wear as well, mine were not in good shape after weeks of searching on-line and asking around I took the suggestion to have them hard chromed. I gave the shop the new bearings so that they could machine to a nice fit. Just a thought.
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Nov 2010 Posts: 30 New Guy | | New Guy Joined: Nov 2010 Posts: 30 | Mine will fall through the spindle. The assembly had noticible play before I took it apart. I understood the bushing are press fitted into the spindle with light pressure. Anyway I think they are too loose. As an alternativr to a new spindle, I am looking for oversized bushings as a solution, then machine the spindle for them.
