1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 24 New Guy | | New Guy Joined: Jan 2012 Posts: 24 | Hi all. I've looked all over for replacement wheel well panels for my truck. Mine aren't rusty but someone cut them out. I just want to get the original symmetry back into the look of the truck. Anyone have any resources or ideas? I've looked all over the web for panels and most info I found was from 2008 or older. Thought maybe someone like LMC may be producing the panels? Thank you. [IMG] http://i484.photobucket.com/albums/rr206/64fordf260/apache.jpg[/IMG] Here is a link so you can see what it looks like now, just not right. I've looked for a donor bed but no luck.
59 Apache Long Fleetside 4x4 Big Back Window 53 Chevy 3/4 ton Longbox 63 Chevy Shortbox 64 Chevy Longbox 4x4 71 AM General Deuce and a half M109A3 84 Chevy Blazer M1009 Diesel 83 GMC 3/4 ton 4x4
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the garage, your only hope is a post in the parts wanted here or a DIY fab job, no repro patches available and the beds are scarce ... stepside fenders [ same as panel] could supply the basics to get the molded edge - just need to be stretched a bit Bill | | | | | Joined: Jan 2012 Posts: 24 New Guy | | New Guy Joined: Jan 2012 Posts: 24 | Thanks for the welcome Red. I have an english wheel but it is to big to build the lip and get the right roll. I have been looking for an eastwood fender roller to make the fender lip but I would rather rent one then buy as I wouldn't use it much. Thanks for the info on the burb and stepside. I will probably look for a couple stepside fenders and use the lip after stretching to get the contour.
