3 members (Gib70, Woodcmiami, Danielbolt), 318 guests, and 3 robots.
Topics128,152
Posts1,057,011
Members48,460
I have two parts List from 1929 to 1975 Chevy Parts.
Neither of them cover Suburban/Carryall body parts.
On page 585 of my 1929 to 1946 Chevy Parts List they say see Price List Supplement(P & A 24D revised) effective April 30, 1942 for all special parts on the following Special Models.
One of the Special Models is 1935 to 1942 Suburban Carryall Bodies. Two Questions,
Does anybody have a copy of this list referred to above?
Can anyone tell me if the Art Deco Suburbans 1941 to 46 and the AD Suburbans used the same lift gate hinges?
Thank you,
Dave Murray
[email protected]
Dave,
The panel-body parts are often in the last few sections of this Master Parts Book.
http://chevy.oldcarmanualproject.com/1929_54chevyparts/16/729.HTM
If no one else responds by the time I get home, I'll look up the parts.
http://chevy.oldcarmanualproject.com/1929_54chevyparts/17/778.HTM
A few shared parts and few differences between 39-46; however, Advance-Design end-gate hinges were different from the earlier ones.
Tim, Are you referring to the lower hinges, upper hinges or both.
Many thanks,
Dave Murray
Dave,
For what years?
It looks to me that no hinges from 47 onwards are used on 46 and earlier.
The differences in the various hinges from 39-46 are also listed.
They are not the same for the two different series. The Art Deco trucks used at least one style and the AD series used two different styles. 1947/1950 and 1951-1955.
Let's see if we can get someone to post a picture of their hinges so we can see the differences.
1941/1947 hinge not the best detail. but I can definitely see the difference between the AD and the art deco series.
EXPLODED VIEW OF CLAMSHELL DOORS 1941/1946
The '40-'46 End Gate Hinges are Group # 17.208 in most of the Master Parts Catalogs, and are also listed in the Special Model Supplement mentioned above printed in 1942. The part numbers for the upper hinge and link assembly are: 3800497 (LH) and 3800498 (RH). There are also some other part numbers listed for the Hinge Housing, Hinge Pin, and Hinge Reinforcement. The AD Subs had different parts numbers for these hinge pieces, so as has been said, the parts are different.
To be long remembered as he's cruising in
The Passing Lane
Thanks for the help everybody, I was hoping they carried the design over.
Obviously the two sets I have are rare and difficult to duplicate.
It would appear that the lift gate pulls away from the body before and then as it lifts up as well.
There are actually two pivot points.
Thanks again to all who had input here. I will be very careful when I open the lift gate.
Jody,
Welcome to Stovebolt.com
Personal communications should be done in email or Private Messaging. This a Catch-22 situation, since new members have to make 5 posts before they can make a Private Message (you might be able to click on a member's name and see the email address).
You might want to put your email address in your Profile: [email protected]
Here is Murraydave's email address (it is in his profile): [email protected]
This message will be deleted in a few days.
