| | | Forums66 Topics128,185 Posts1,057,275 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | I need help with the Lower Radiator Hose part number. I have a 1956 3100 with the stock radiator in the 6-cylinder location with a sbc V8 engine. What hose will work? I'd like to find a molded hose and not use the universal flex hose. Thanks, Mike B
Last edited by Woogeroo; 01/25/2012 11:00 AM. Reason: added year/model/ v8 swap to post
| | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy Mike B, see if you can look at Dayco p/n 70277 $9.23 at RockAuto, they do show a picture , but give no dimensions. Original application 1959 1/2 ton V8, hope that helps. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Thanks 3B, I crossed that hose to NAPA 7165 and that might work...I'll call my local NAPA tomorrow and see if they have it in-stock. I have a NAPA 7695, but the leg coming off of the water pump is to short allowing it to touch the AC belt as it makes the 90* bend heading for the radiator. The 7165 looks longer... I'll keep you posted. Mike B  | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | I have used the lower hose for a 65 V-8 truck in a couple of TF 6 to V-8 conversions. It needs to be cut slightly but has the correct bend. I don't remember the PN but most parts stores should be able to look it up. The stock TF V-8 hose is too short because of the location of the radiator. Fred
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | I ended up using a NAPA 7694. It is 1-3/4" hose with a 90* bend. It clears the AC belt and goes straight into the radiator. It could have used a couple degree bend at the radiator end, but the hose is long enough that it's not a problem. I'll take a look at the 65 truck hose...it might be better? Thanks, Mike B  | | |
