3 members (Chip O, 1955 1 Series, Barry Martak), 117 guests, and 3 robots.
Topics128,095
Posts1,056,477
Members48,444
#81942 08/24/2007 5:38 AM
anybody swap in a modern 2000 and newer eng./tranny combo? I'm looking to swap into my 51 chev/s10 chassis truck. any info would be great! :hammering:
#81943 08/31/2007 1:29 AM
You will need to go aftermarket for programming and rewiring to a 5-wire connection. Or grab the entire wiring harness, ECM/PCM and steering column from the donor to get the thing started. You will also need the fuel pump, however do some digging on the web, as there are ways arround that. Westers Garage (mentioned in the forums) is one of many places that does reprogramming.
#81944 08/31/2007 7:51 PM
Junior Member
Junior Member
JW, Like you said in the gallery section, if you are planning on doing the swap, and have the space for it, get a salvaged vehicle so you can pick up all the wiring, fuel pump, accessories, and computer. I am doing a swap with a 2004 5.3L, however I am doing it the easy way with a carb setup. There are two sites that can help with info on that generation of engine. www.ls1tech.com and www.67-72chevytrucks.com I have had to use this site as well as the others for researching the swap. I am basically in mocking up stage on my swap, installing mounts. I a crossmember style tranny/engine mount from CPP, however there are a ton of venders selling the stuff. So far they have worked fine. The one problem that I am still researching is exhaust manifolds as the truck manifolds I got with my engine dump right into my frame rails. If you have any other questions, I'll try and help.
Corey
#81945 09/01/2007 4:28 AM
Junior Member
Junior Member
Sorry, thought of some more info that may help. I had always seen the high dollar LS1 swaps and never paid any attention to them. In Car Craft Magazine, they had an article about buying a boneyard truck 6.0L and they got some good power out of the thing. http://www.carcraft.com/projectbuild/116_0704_lq4_short_block
480 HP for $3,775. Not cheap, but shows the thing has potential. If you are a high tech guy, the Fuel Injected engine is an awesome setup. I always thought when I rode in my Dad's 2001 Chevy that it would be awesome in an Advanced Design pickup. The LS1 site I recommended above also has a conversion forum where there are a lot of S-10 guys doing the swap. They should be able to steer you toward the exhaust, and engine mounts that will clear the chasis. I am still trying to find someone doing a similar swap to mine. (stock suspension) Most people are going to go with a custom IFS setup if they are going to put in all the work for an engine swap. If you want any info on a carbed swap, I can tell you some of the things I have learned.
