9 members (WICruiser, Gray_Ghost, Oswald, Hambone, DaveV, TUTS 59, jmoore, Goach2, Phak1), 110 guests, and 5 robots.
Topics128,184
Posts1,057,271
Members48,467
I need help with the Lower Radiator Hose part number. I have a 1956 3100 with the stock radiator in the 6-cylinder location with a sbc V8 engine. What hose will work? I'd like to find a molded hose and not use the universal flex hose.
Mike B smile
Last edited by Woogeroo; 01/25/2012 11:00 AM. Reason: added year/model/ v8 swap to post
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
3B Offline
Hy Mike B, see if you can look at Dayco p/n 70277 $9.23 at RockAuto, they do show a picture , but give no dimensions. Original application 1959 1/2 ton V8, hope that helps.
Thanks 3B,
I crossed that hose to NAPA 7165 and that might work...I'll call my local NAPA tomorrow and see if they have it in-stock.
I have a NAPA 7695, but the leg coming off of the water pump is to short allowing it to touch the AC belt as it makes the 90* bend heading for the radiator. The 7165 looks longer...
I'll keep you posted.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I have used the lower hose for a 65 V-8 truck in a couple of TF 6 to V-8 conversions. It needs to be cut slightly but has the correct bend. I don't remember the PN but most parts stores should be able to look it up. The stock TF V-8 hose is too short because of the location of the radiator.
Fred
I ended up using a NAPA 7694. It is 1-3/4" hose with a 90* bend. It clears the AC belt and goes straight into the radiator. It could have used a couple degree bend at the radiator end, but the hose is long enough that it's not a problem.
I'll take a look at the 65 truck hose...it might be better?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
