0 members (), 182 guests, and 1 robot.
Topics128,108
Posts1,056,228
Members48,436
#819030 01/23/2012 9:55 PM
I am about to replace my original speedometer etc. with a new dash insert and gauges from Classic Instruments. Any suggestions on where to buy the insert. I've seen the ones manufactured by Boese Engineering, but am looking for other choices.
You might be better posting this in the HiPo section,not everyone looks in here.....
Good luck!
More pix on Flickr.
You can also do an E Bay search for " Billet Aluminum " inserts - there seem to be a few different versions around.
1940 Chevy KC 1/2-Ton
http://www.classicinstruments.com/gaugeselector.aspx?ProductCode=VT34SLF&SeriesCode=VT
I like the ones above if you go with a 3 gauge setup. I bought Dolphin, like the looks of these slightly better if they had black needles instead of red.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
Thank you, guys. I've got some good ideas and will be making my purchase shortly.
