1 members (baldeagle), 79 guests, and 1 robot.
Topics128,037
Posts1,055,467
Members48,424
#818896 01/23/2012 1:31 PM
Truck: 1953 1/2 Ton 3100
Engine: Original 216 running 6V Generator
I had been having problem with a weak starting engine with idle problems and hesitation. I replaced grounding straps, battery, battery cables, starter wire, and then rebuilt the Rochester B Carb after noticing it seemed to be running very rich and leaking onto manifold. Sure enough the float was way high leading to excessively rich mixture. Now, it will start quickly and idle without the usually required 1-2" of choke.
I am not sure if I set the choke cable properly into the carb nor if the idle mixture screw is set correctly. It seems like it is idling really low, which might be OK but doesn't sound right. Doesn't sound like a normal Stove bolt 216 if that makes sense. Missing that steady quiet lobing sound...
Additionally the engine seems to shake the cab and frame side to side more than before. Does that make any sense? Seems almost like a misfire issue or is the usual firing just more pronounced at a irregular low idle? This was not noticed before the Carb work. Everything has been checked electrically to ensure all distributor and coil cables are clean and tight. Nothing seems to be loose or moved.
Thoughts?
Thx!
Saint #818899 01/23/2012 1:49 PM
Here is where I would start: let it warm up, bring the idle speed up until it smooths, then adjust mixture screw for best idle speed. Then reset the idle speed screw for the idle that you like. If you have already done this then once it's running turn your distributor and see if it smooths. Check for vacuum leaks. If all is well there, I would recheck floats.
Hope this is helpful.
Mark
1951 Chevy 3100
Some days you get the bear. Some days the bear gets you.
Saint #818907 01/23/2012 2:12 PM
Have you checked ignition timing?
idling adjustment
My truck rocked pretty good when I accidently crossed #1, #6 plug wires during a timing check.
mixture screw set to far in
set correctly
just a few things to look at
Good Luck
DADS50 #819063 01/23/2012 10:59 PM
Thanks for the info, Mark & Dads50!
Saint #819098 01/24/2012 1:05 AM
I just finished a 235 with a rough idle, vacuum leak at intake.
Gmans 46 #819588 01/25/2012 12:19 PM
Hey Saint,
Hows that engine running? Did you get a chance to look it over?
Mark
1951 Chevy 3100
51bolt #820191 01/27/2012 12:27 PM
Hey Saint!
Have you had time to work on this? Let us know what you find.
Mark
1951 Chevy 3100
51bolt #820357 01/28/2012 1:19 AM
Gets better when you speed it up: intake leak
Gets much worse when you speed it up: 1 cylinder is out (fouled plug, bad wire, cracked cap)
