4 members (Gdads51, Jon G, Otto Skorzeny, UtahYork), 44 guests, and 1 robot.
Topics128,090
Posts1,056,020
Members48,430
#818827 01/23/2012 3:43 AM
Hi I have a 292 and it is back fireing thru the carb what is the problem just had a shop do a lot of work on it and not happy! Also when trying to start it seems like no gas Pump is working fine and it has gas but plugs are dry and just truns ans truns and there is spark.
What kind of work was done?
carb rebuilt new plugs points and cap and rotor and coil
Maybe plug wires got put in the wrong holes on the distributor causing the back fire.
Float too low or accelerator pump not working.Perhaps points are not adjusted correctly.
Just a shot in the dark.
Valve adjustment?
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
