3 members (tesa, Hotrod Lincoln, Nick in Manitou), 169 guests, and 2 robots.
Topics128,088
Posts1,056,002
Members48,430
#818565 01/22/2012 10:27 AM
I have a '56 GMC V8 with a Hydramatic Trans that I am starting to restore. I need help in deciding the pro/cons of replacing the 12 volt generator with another generator or changing to an alternator. I'm not sure which would be better as this will be my primary driver once she is running. Thanks!
Jon
Jon
1956 GMC
"Man is not disturbed by event's, but by the view he takes on them." -Epictetus, Greek slave and Stoic Philosopher
Ex Hall Monitor
Ex Hall Monitor
I put a 6v alternator on my '38 and love it.
Riding in the Passing Lane
If you are going to make a driver out of it definitly change to an alt. with internal regulator. It charges at idle & dependability is much greater. The voltage is more stabilized makeing the bat & acesseries last longer.
1972 Chevy c10 Cheyenne Super
In addition to what has been mentioned a gen will go thru a set of brushes sometimes in 20k miles where an alt will usually go for 100k.
Thanks for the input. As far as I can tell, it's still the original generator still.
Jon
1956 GMC
