1 members (Hotrod Lincoln), 69 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
There is weatherstrip on the door itself but none one the cab and I can see daylight
I know about the windlace and the channel it fits in is there anything else . anybody have any upclose pictures of a fully weatherstripped door
Y
Y Offline
If you can see daylight, then couple of things come to mind. Door isn't closed all the way shut or it needs new weatherstrips! Doors should have "two" latch positions, make sure the door is getting closed.
Thanks just got this truck and know little about it. Will check this out as neither door seems to shut well,
There should be weather stripping on both the door and the cab. You may be missing the cap weatherstrip. It slides into the channel on the inside of the cab. Replacement is available from many places. It can be pretty tough to slide a whole new strip in. I purchased one that I just couldn't make work. Then I purchased a good quality rubber one from Steele and it went in pretty nicely and looks and works great.
Moderated by  ndkid275, Phak1
