9 members (JoergK., Bill Hanlon, J Lucas, Chip O, dt235sd, Gdads51, Hotrod Lincoln, 2 invisible),
75
0
Mod | | | Forums66 Topics128,205 Posts1,057,427 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You have the same radiator as the U.S. made GMC's (very close anyway). These radiators GMC type have a different tank top like yours with a surge/expansion feature incorporated in. The Chevrolet top tank has a different filler neck and bottom tank is straight out on the hose attachment and it does not have the surge features. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That is not the same as a US GMC radiator. They are similar with the pressure relief built into the left side and they do have side mounts but they mount further forward under that top cross bar and have a filler neck on the right aft side, not top side.
I'll take some pics later. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Perfect, this is something that I've always wondered about. | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy Mr Lang, Canadian GMCs with Chevrolet engines in them also have Chevrolet front frame crossmembers in them, this is to allow the shorter Chevrolet engine to fit properly, just one more thing to think about when swapping to a GMC engine, hope that helps. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Ahh, so I would need to replace the cross member too. Well now, you learn something new every day.
This is just the sort of information I'm looking for.
I'm sure this is old hat to many of you, but I figured the only way to learn was to ask? | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Question? Is it a different cross member or is it just located in a slightly different location. Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Question? Is it a different cross member or is it just located in a slightly different location. Larry It is a different cross member (in the USA GMC trucks). It looks like they are using the same attachment locations. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Tim, as usual, that picture is just the ticket! | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Anyone ever change the crossmember? | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I believe I read over on oldgmctrucks that a fellow did just that, he used grade eight bolts to bolt on the GMC crossmember. I think this was to install a big 'ol 302. I think that would be a noticeable difference when compared to a 216! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I can confirm the rivet holes are the same. I built a run stand from a frame and have interchangeable cross members. | | |
