3 members (DaveV, Phak1, TUTS 59),
223
Mod | | | Forums66 Topics128,162 Posts1,056,942 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 40 | Looking for some help in finding a replacement axle for my 46 3/4 ton...don't care if it is 5 or six bolt pattern...would like a 3:90 or 4:11 posi rearend...need some direction to which make and model may have what I need. The distance from one backing plate to the other is 52.5"...I have gone to several junk yards and there so many...but no cigar in a close measurement...I will be mating this to a 700R4 transmission. John
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Since you are going with a 700r4, you'll need a rearend for an open driveline truck. Most truck rears from the mid 50's on up should fit the bill. An S10 rear should be easy to find with lower gears, as well as a Ford Explorer 8.8 rearend. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | If you have a 46 3/4 ton, you already have an open drive rearend. Is your truck 6 lugs or 8 lugs? | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | i don't know how much difference there is in my 38 and your 46 but i have a s-10 rear i got with my truck "not installed" it has a disk setup and from every measurement i did the disk brakes would be hitting the frame so add tires to that and i don't see that working to well
1937 1/2 ton
