| | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 27 New Guy | | New Guy Joined: Nov 2006 Posts: 27 | I need help identifying if I have the correct starter and length of travel.
The truck is a 54 GMC 3/4 ton with a 248.
My starter spins on occasion. When I turn the key again 90% of the time it cranks right over. I have had the starter rebuilt for a second time. The most recent was a very reputable shop and a guy that works on all the old stuff.
I can see some teeth wear on the flywheel on several spots maybe as much as a 20% to 25% worn. It still seems to have plenty of tooth to engage. The gears on the starter are new.
The starter number is 1107109 and a 101 on the nose. I feel the starter number is correct.
The nose is a total of 3-3/8" total from housing to longest point. The teeth on the starter start at 1-3/4" from the housing and at maximum travel go to 2-1/2" The flywheel is about 2" from the bell housing.
The flywheel is 3/8" thick.
The math seems correct to me but the starter guy seems to think my nose is too long and the starter gear goes in to far and does not get enough momentum to engage sometimes.The starter guy says it might need to be packed out 1/4" with shims. I did see a hydra-matic starter on eBay recently for a '55 gmc with a 270 engine with a shorter nose? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Hello, Bruce,
Post this question over on oldGMCtrucks.com
I have one GMC parts book through 1953 and another parts book for 1955 and later.
The earlier book shows your part number for 1953 GMC 350 (2 ton) with Hydra-Matic. That part number is not shown for 55 and later. You/we need a GMC parts book with Z-series (54/55) data.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bruce, Here is a photo of the two solenoid starters used by GM in 1954. The 1/2-1 ton Hydra-Matic truck starter is on the top, and the 49-54 DUBLI-DUTI and 50-54 Powerglide car on the bottom. The "snouts" are different and may be interchanged. | | |
