6 members (artinva, RoadsScholar, Hotrod Lincoln, Bill Hanlon, Gdads51, 1 invisible), 88 guests, and 1 robot.
Topics128,078
Posts1,055,936
Members48,430
#817 09/06/2002 2:53 AM
I have a 1950 1/2 ton pickup with the Patrick saginaw 4 speed and 3.55 rearend conversion. Drive it about 60 miles a day doing about 60to65 mph. I think the engine was rebuilt with insert bearings by local Norwegian rancher. Would splitting the exhaust manifold, Fenton headers, or Clifford headers be a reasonable improvement? I would like to have good cold weather performance.
#818 09/06/2002 4:12 AM
Increasing the airflow through the engine will help, but it comes at a cost, you will lose low end torque. Splitting the exhaust manifold is about the cheapest way to go, not sure if you can keep the heat riser operative, though.
More carburation will help, too. You have some options. Simplest is to go to a two barrel, two stage carb, the Holley-Weber. Will still keep the torque up, and will help open up the top end. With different manifolds you can go with dual Rochester ones, dual Holley-Weber twos, or a single four.
Another area to improve is the ignition. If your distributor isn't worn out, you can add in a Pertronix electronic ignition for about $85. A GM HEI from a newer six can be adapted, but they are getting hard to find. Mallory Unilite is good, but expensive. Another option that can be used with or without HEI is an MSD-5 or -6 box, which will give multiple sparks every time a cylinder fires.
Now, if you have any money left wink we can discuss cams.
Fred
52 3600
69 C-10
#819 09/07/2002 4:09 AM
Thanks for the idea about pertronix. Will it work with 6 volts?
#820 09/07/2002 4:40 AM
12 volt only.
Fred
52 3600
69 C-10
