| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 196 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 196 | What else is out there aside from the Shop Manual!???? I could use more literature, diagrams etc for my '46!!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | might find some here: http://chevy.oldcarmanualproject.com/if you want hard copy, check all the vendors and watch ebay Bill | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | There is usually the
Shop Manual and the shop manual supplements for years following. In your case, the '46 manual is probably the supplement and there is a older manual with more information in it.
owner's manual(which, the older the vehicle, the more information there is in there)
Some models have the 'accessory installation manuals' which go across all models of cars and trucks for that year, don't know if they had one for 1946 or not.
check out the links section, go to parts and look in the manuals/literature sections.
American Classic and Classic Parts of America both have pretty thorough literature sections for our old trucks.
-W
| | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | Master parts books are also helpful. The old chevy manual site has several to look through, otherwise they show up on ebay.
I like the parts books for having good exploded views/cutaways of components and helping determine what interchanges between years. This is good knowledge to have when going to swap meets, etc. (Never ask the seller if it will fit your vehicle...everything will fit with either a hammer or torch!)
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | I picked up the factory assembly manual for mine which shows allot of detail through assembly....I'll need it once I start to re-assemble it. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I would think you should have the following: Owners manual shop manual accessories sheet or manual Look under literature here literature Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Andy, Have you tried Brads site? He has a lot of good diagrams and info. Have fun and good luck Dan | | |
