3 members (Gray_Ghost, Mike34, Otto Skorzeny), 91 guests, and 3 robots.
Topics128,048
Posts1,055,664
#816989 01/17/2012 3:10 AM
I have a 1951 chevy 3600 that I want to put the T5 in. I have a chevy 250 from 68 going in it. Can some one please tell me which T5 will go in it. If you have a year to look for or the tag # and from what motor will will. Please help
Riding in the Passing Lane
All of them from the S-10 pickups fit with the normal modifications. You need one with the mechanical speedo drive unless you run an electronic speedo. There are also variations in the gear ratios. The best one & most common one is the 1352-145. It came on most mid 80s with both 4 & 6 cyl. engines. 89 up are electric speedo & some 88s also.
1972 Chevy c10 Cheyenne Super
thanks wrench for the response. Do you know how hard it is gonna be to do the hydraulics for the tranny.
There are no hydraulics. You use the same clutch system you had except a different disc.
George,what about the bell housing for a 250 ? I'm curious about it.
Tim
1951 3100 Chevrolet
The 250 bell houseing is the same as a V-8. Some 68 up had a larger hole in the center for SM 465 4 speed trans. & possibly other trans. The car bell houseings are smaller with the small 152 tooth flywheel. I believe all the trucks used 168 tooth flywheels. If a guy is putting in a NV3500 5 speed he will need to set up a hydraulic clutch as the bell houseing is built in to the trans.
If you are going to put the T5 behind the 250, you'll need a V8 bellhousing and not a 4/6 bellhousing. The 4.3 6 cylinder bellhousing will work, but not the smaller 2.8.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
