| | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 12 New Guy | | New Guy Joined: Jun 2011 Posts: 12 | I have a 1951 chevy 3600 that I want to put the T5 in. I have a chevy 250 from 68 going in it. Can some one please tell me which T5 will go in it. If you have a year to look for or the tag # and from what motor will will. Please help | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | All of them from the S-10 pickups fit with the normal modifications. You need one with the mechanical speedo drive unless you run an electronic speedo. There are also variations in the gear ratios. The best one & most common one is the 1352-145. It came on most mid 80s with both 4 & 6 cyl. engines. 89 up are electric speedo & some 88s also. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2011 Posts: 12 New Guy | | New Guy Joined: Jun 2011 Posts: 12 | thanks wrench for the response. Do you know how hard it is gonna be to do the hydraulics for the tranny. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There are no hydraulics. You use the same clutch system you had except a different disc. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | George,what about the bell housing for a 250 ? I'm curious about it.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 250 bell houseing is the same as a V-8. Some 68 up had a larger hole in the center for SM 465 4 speed trans. & possibly other trans. The car bell houseings are smaller with the small 152 tooth flywheel. I believe all the trucks used 168 tooth flywheels. If a guy is putting in a NV3500 5 speed he will need to set up a hydraulic clutch as the bell houseing is built in to the trans. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | If you are going to put the T5 behind the 250, you'll need a V8 bellhousing and not a 4/6 bellhousing. The 4.3 6 cylinder bellhousing will work, but not the smaller 2.8. | | |
