8 members (tclederman, 68ironhead, 3B, GMCJammer51, Otto Skorzeny, Pre '68 Dave, Jon G, 1 invisible),
124
Mod | | | Forums66 Topics128,110 Posts1,056,245 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 25 | I'm rebuilding a Carter W-1 574 carb for my truck and am stuck at one point of the reassembly. Under the dust cover there is a rotary spring that keeps the pump lever in contact with the plunger rod. I can't remember how that spring goes back on. Can anyone help me with a picture or diagram showing that spring? Thanks in advance for any help | | | | | Joined: Jan 2011 Posts: 7 New Guy | | New Guy Joined: Jan 2011 Posts: 7 | The short leg of the spring goes through the hole and the longer leg goes down and hooks around the round push rod. Kind of a up-side-down L. I took some pictures with my phone but you really cant see anything. I can try again if you need it. | | | | | Joined: Jan 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 25 | Ok - which hole are you talking about. The hole on the lever or the hole on the pump rod. My pump rod is the rectangular one not a round one. A picture would be really great if possible. Thanks! | | | | | Joined: Jan 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 25 | Just another thing. My spring has one end with a bent 90 degree end. The other end of the spring is straight. | | | | | Joined: Mar 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 46 | I've got a photo and can post it tomorrow morning. | | | | | Joined: Mar 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 46 | | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Doug, Check out this site. It gives detailed instructions on rebuilding the Carter W-1. http://www.thecarburetorshop.com/Carter_W1_service.pdfGood luck, Harold
Harold Is a restoration ever finished? | | |
