| | | Forums66 Topics128,049 Posts1,055,695 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81732 08/20/2007 9:08 PM | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | The ignition switch on my '62 does not have an accessory position. Is that the way the original switches were, or do I have some sort of replacement switch ? If it is original I want to change it for one that has an accessory position. Any suggestions appreciated. | | |
#81733 08/20/2007 9:41 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I don't think that the Accessory position was added to trucks until '67. I suppose you could use the later switch, also used in vans up to the early '80s, if it will fit the hole in the dash. Is there any particualr reason you want an Accessory position on the ignition switch? I just added a secondary switch in the wire going to the coil to kill the power there when I only want to run the accessries.
Bill Burmeister | | |
#81734 08/20/2007 10:25 PM | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | I want the accessory position for the radios - the regulatr radio and the cb. Thanks for the info. I'll use a '67 or later. | | |
