1 members (stoveboltgator), 218 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#81732 08/20/2007 9:08 PM
The ignition switch on my '62 does not have an accessory position. Is that the way the original switches were, or do I have some sort of replacement switch ? If it is original I want to change it for one that has an accessory position. Any suggestions appreciated.
#81733 08/20/2007 9:41 PM
I don't think that the Accessory position was added to trucks until '67. I suppose you could use the later switch, also used in vans up to the early '80s, if it will fit the hole in the dash. Is there any particualr reason you want an Accessory position on the ignition switch? I just added a secondary switch in the wire going to the coil to kill the power there when I only want to run the accessries.
Bill Burmeister
#81734 08/20/2007 10:25 PM
I want the accessory position for the radios - the regulatr radio and the cb. Thanks for the info. I'll use a '67 or later.
