2 members (TUTS 59, Ponchogl),
106
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 |
Can a mechanical vacuum advance work intermittently or is it an all or nothing scenario?
Thanks, Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | It's simply a vacuum diaphragm, when the is vacuum suck the air out of it, it moves in compressing a spring and when the vacuum is removed and it rises back up to atmospheric pressure the spring pushes it back to its stop. If you mean by intermittent, can it operated in between full vacuum advance and no vacuum advance, yes. I does operate anywhere in between depending on the strength of the vacuum signal.
Denny graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Dale,
If you have a hole in the diaphragm, the vacuum advance is not going to work at all. So it's an all or nothing scenario. The mechanical advance would still work however.
(Denny, just another interpretation of what the "intermittent" question might mean)
Kurt | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | thanks,
What I meant was, can it work... moving the distributor then not work, then work again under normal circumstances?
you both have answered my question. I must have another issue.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Oops, thought I read into it that he was asking about the vacuum advance not the centrifugal mechanical advance.
DG
| | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | When I got my 54 the po said the vac. advance worked when it was warm. I never found that and replaced it. I guess you could call that intermittent. | | |
