7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81711 08/19/2007 5:44 PM | Joined: Jul 2005 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 153 | Guys
Putting power steering in my 70 1/2ton. What dbl groove water pump pulley can I use? Will a small block long or short pulley work or do I need to find a pulley of another 250?
Thanks, Mac | | |
#81712 08/19/2007 9:19 PM | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | good question. i thought you always had to get a double pulley off a 250 ot 292. i don't know if a v8 one would work. the power steering bracket and a/c bracket seem to be the most hard to come by items. i've sold several on ebay. good luck and can't wait to see what everyone else says. hr | | |
#81713 08/20/2007 2:05 AM | Joined: Jul 2005 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 153 | I got the PS brackets but neverthoght about the pulley. The crank already had a double row pulley. Ok experts chime in. I'm so close to having power!! | | |
#81714 08/20/2007 6:00 PM | Joined: Jul 2005 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 153 | here's what I found out from an inline expert. The bolt pattern for the 250 water pump is the same as the sbc's. The depth is almost identical to the long pump pulley, shims may be necessary but not always. The difference is diameter of the 250 is larger than the sbc. So I put a small block long pump pulley and switched out both belts to a shorter length. I'm crusin with power baby! | | |
#81715 08/21/2007 2:17 PM | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | good to know. i bet the smaller diameter pully shouldn't make much difference in operation of water pump. now you will be able to whip around in parking lots with one hand.  | | |
