3 members (Pre '68 Dave, 52Carl, Bill Marlow), 50 guests, and 2 robots.
Topics128,090
Posts1,056,028
Members48,432
#816588 01/15/2012 10:03 PM
8
8 Offline
I have a 48 1.5 ton with a 235 and a Rochester B carb. As far as I know everything is original to the truck. I am trying to decipher the Model number of my carb It appears to be 7084518 C or 7004518 C.
I have had no luck in matching these numbers to various sources on the web.
The other numbers are 22712 on the on the throttle/choke linkage, and 60 or 09 on the air horn portion.
Any advice or suggestions on what carb kit is the most appropriate?
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
8
8 Offline
I emailed the same pictures that I have linked above to the Carburetor Shop, seeking a rebuild kit.
This was their response "These units are identified by tag only. Once the tag has been removed, virtually impossible to identify. Regards."
I rebuilt this carb a couple years back with a Napa kit for some version of the Rochester B. I am trying to find the old rebuild kit box for a part number. Regardless the carb seemed to run great, after I rebuilt it. Now that I have fixed my intake/exhaust/heat-riser issues, I feel another rebuild is in order. If you have any suggestions of which 'basic" kit I should get or any major differences in the kits please let me know.
Curt Warren
Salt Lake City
