4 members (UtahYork, tclederman, 50Chevy3100, 1 invisible), 106 guests, and 3 robots.
Topics128,087
Posts1,056,377
Members48,442
U
U Offline
Hey guys, I am swapping frames on my 1955 2nd Burb. The rear cab mount on the orig frame is exactly 3 feet from the front cab mount. Do you guys know if that is correct or is my Burb special. The new frame I have puts the mounts about 44" or so apart.
1969 Camaro SS #s Matching
1955 Suburban Carryall (Cummins powered in the works)
2002 Camaro SS LE#1320
2011 RAM 2500 6.7 CTD Laramie Longhorn (H&S Mini Maxx and all the EPA crap removed smile
U
U Offline
no one?
Anyone have a 55 frame they can measure front mount hole to rear mount hole?
might be able to figure things out from the rest pack - is the 'new' frame from the exact same year and model, or is it maybe from a pickup or canopy express or .... 55.1?
laying on the cold concrete, the completed '56 sitting here measures about 3' from the front toe board mount [like a pickup] to the mounts on the outside of the frame near the front of the gas tank
U
U Offline
I think the new frame is for a truck. I thought the cab mounts were the same, but I am wrong I guess.
the panel mount in the 2nd position [outside the frame] is different than the pickup, but the long panel/canopy express are spread further - if you have the original frame for the panel you could move the mount brackets to the new frame, should have the necessary mounting holes in the rails
