| | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 14 New Guy | | New Guy Joined: Oct 2010 Posts: 14 | Hey guys, I am swapping frames on my 1955 2nd Burb. The rear cab mount on the orig frame is exactly 3 feet from the front cab mount. Do you guys know if that is correct or is my Burb special. The new frame I have puts the mounts about 44" or so apart.
1969 Camaro SS #s Matching 1955 Suburban Carryall (Cummins powered in the works) 2002 Camaro SS LE#1320 2011 RAM 2500 6.7 CTD Laramie Longhorn (H&S Mini Maxx and all the EPA crap removed | | | | | Joined: Oct 2010 Posts: 14 New Guy | | New Guy Joined: Oct 2010 Posts: 14 | no one?
Anyone have a 55 frame they can measure front mount hole to rear mount hole?
1969 Camaro SS #s Matching 1955 Suburban Carryall (Cummins powered in the works) 2002 Camaro SS LE#1320 2011 RAM 2500 6.7 CTD Laramie Longhorn (H&S Mini Maxx and all the EPA crap removed | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | might be able to figure things out from the rest pack - is the 'new' frame from the exact same year and model, or is it maybe from a pickup or canopy express or .... 55.1? laying on the cold concrete, the completed '56 sitting here measures about 3' from the front toe board mount [like a pickup] to the mounts on the outside of the frame near the front of the gas tank Bill | | | | | Joined: Oct 2010 Posts: 14 New Guy | | New Guy Joined: Oct 2010 Posts: 14 | I think the new frame is for a truck. I thought the cab mounts were the same, but I am wrong I guess.
1969 Camaro SS #s Matching 1955 Suburban Carryall (Cummins powered in the works) 2002 Camaro SS LE#1320 2011 RAM 2500 6.7 CTD Laramie Longhorn (H&S Mini Maxx and all the EPA crap removed | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the panel mount in the 2nd position [outside the frame] is different than the pickup, but the long panel/canopy express are spread further - if you have the original frame for the panel you could move the mount brackets to the new frame, should have the necessary mounting holes in the rails
Bill | | |
