| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#8167 11/02/2004 12:00 AM | Joined: Jun 2002 Posts: 53 Member | | Member Joined: Jun 2002 Posts: 53 | Can someone help me decode this engine code 270956I00 I have a bell housing with the clutch fork on the right side. Can someone tell me what this might of came out of? I am looking for a bell housing with the clutch set-up for the left. Does anyone know where I can get one? Thank you. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Is this in a GMC? Engine appears to be a GMC 270 because of the first 3 numbers.
Fred 52 3600 69 C-10
#8169 11/02/2004 10:02 AM | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | | | |
#8170 11/03/2004 12:36 AM | Joined: Jun 2002 Posts: 53 Member | | Member Joined: Jun 2002 Posts: 53 | Fred, It did come out of a GMC. | | | | | Joined: Feb 2004 Posts: 29,743 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,743 | Right or left, from what perspective? The normal bellhousing has the clutch fork coming in from the driver's side, while the late-50's pickups had hydraulic clutches, with the fork entering from the passenger's side. Does your bellhousing fit a 6-cylinder, or a V-8? I've got several hydraulic clutch V-8 bellhousings, and I know where a manual-clutch V-8 bellhousing is that I've been intending to purchase, and just haven't gotten around to doing it. These are the ones with motor mount bolt holes in the bellhousing. Sorry, I can't help if it's for a 216/235/etc. engine. Jerry
| | | | | Joined: Jun 2002 Posts: 53 Member | | Member Joined: Jun 2002 Posts: 53 | Jerry, The one I have bolts up to a 270. I am trying to find a bell housing with clutch fork on the left side. Thanks | | |
#8173 11/04/2004 12:21 AM | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | Napco, I have a bell housing from 1954-62 truck with clutch fork on left. | | | | | Joined: Jun 2002 Posts: 53 Member | | Member Joined: Jun 2002 Posts: 53 | Where are you located ChevyB | | | | | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | I am near Richmond ,Va. E-mail me. | | |
