12 members (Charles in CA, MickeyP, GIJOE298, joe apple, Jon G, Ribside, 3B, Bill Hanlon, lumbersawyer, 55shaker, dt235sd, 1 invisible), 97 guests, and 2 robots.
Topics128,134
Posts1,056,738
Members48,454
#815765 01/12/2012 5:31 PM
Is there a donor drive shaft that would be a direct replacement? I have a small block with original mounts, TH 400 trans., 12 bolt rear end. I need a drive shaft,prefer a one peice. I would like to find one that would fit with only minor modifications. Thanks
Not sure of a direct replacement, but if you have a suitable one piece to use there are specialty shops that will lengthen or shorten them to fit. Best to have a pro do it, as it will also need to be balanced.
