11 members (Otto Skorzeny, Southerntruck, D B Cooper, klhansen, Peggy M, Jims46, Hawkman, manymiles, MikeE, joe apple, 1 invisible), 100 guests, and 2 robots.
Topics128,049
Posts1,055,675
#816382 01/15/2012 2:16 AM
here i am again,what should the distance between the fan&raditor.i am using steel fan.i have about 1/2 inch.thanks again.
johnhull #816384 01/15/2012 2:23 AM
half inch is about perfect John, could be slightly closer, but you don't want it any further away
Flxible #816438 01/15/2012 6:10 AM
That's not the critical distance.
The fan can be 3 feet away from the core, if the shroud is a good fit. If it's not, the fan doesn't do much.
panic #816462 01/15/2012 2:10 PM
that is assuming you have a shroud
johnhull #816505 01/15/2012 4:35 PM
What engine?
What truck?
tclederman #816539 01/15/2012 6:38 PM
i should have said my truck is a 1954 gmc1/2 ton.the eng is a mid 70s 250 6 cyl.trans is 700r4.alum.raditor.thanks for all your replys.
