| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | here i am again,what should the distance between the fan&raditor.i am using steel fan.i have about 1/2 inch.thanks again. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | half inch is about perfect John, could be slightly closer, but you don't want it any further away
Bill | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | That's not the critical distance. The fan can be 3 feet away from the core, if the shroud is a good fit. If it's not, the fan doesn't do much. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | that is assuming you have a shroud | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | here i am again,what should the distance between the fan&raditor.i am using steel fan.i have about 1/2 inch.thanks again. What engine? What truck? | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | i should have said my truck is a 1954 gmc1/2 ton.the eng is a mid 70s 250 6 cyl.trans is 700r4.alum.raditor.thanks for all your replys. | | |
