3 members (Bill Hanlon, ShopRag, 1 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,676 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | I came across an adapter bracket that lets you upgrade from a single reservoir to a later model dual reservoir for drum brakes. Has anyone done this? What models would fit? Any mods needed for the brake lines? Is there a benefit to using a dual vs a single? I'm keeping the stock drums front and back. Thanks | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | It's been awhile, but I think I used a MC from a mid 60's Chevelle or the like. Absolutely,you'll have to do brake line work. You have to separate front and back lines and I think I had to use an adapter on an MC port.And I used a different rod to the brake pedal. Works great though. I bought my MC Bracket from Ghostrider here on the Bolt. Putting that in was the easiest part of the whole changeover.
Drew
| | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | I've done it. I used a dual master from a 60's full size Chev car (The first year of dual master cylinders. Can't remember the exact year ('66 or '67)) It's fairly straight forward. Your brakes run on two circuits instead of one so if a leak happens in one line, the other line will still work. Safer because you still will have some braking power. Many vendors sell the bracket. Check out Cletis' tech tip here: http://www.stovebolt.com/techtips/master_cylinder/index.html
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | I asked the same question, can be seen on page 4 with several good responses like yours. In my area its hard to find a wrecker with cars and trucks from the 60s and 70s, saying that though I'm off right now to a yard I was told about to have a look see, then I could order a new one when I feel satisfied. Seems that most of the jobber parts guys either can't or don't want to suggest an alternative, I get the best ideas at this website, good luck
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | I put one in my 3/4T. I went to NAPA and asked for the latest drum-drum master from a Chev 3/4 ton. I believe it was for a '72. Works well and is a factory rebuild, rather than a yard find. I don't mind yard finds, just wanted a little more security with my brakes.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | I used a new master from a brake supply house. The counter guy knew exactly what I needed and almost picked one off the shelf without even looking in 'the book'. I wouldn't use a used one.
| | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Does the dual reservoir work better than the single for stopping power? | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Stopping power shouldn't change much. Mostly I did mine for peace of mind... With the dual circuit system, a leak in one line doesn't mean an immediate loss of all brakes, just the fronts or the rears but not both.
| | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Do both reservoir's on a dual res MC need to be the same size? I've noticed on different models showing a larger front res for disc and smaller rear for drums. I need new brake lines any how so I'm interested in upgrading to a dual res MC for my drums. | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | you could look at an old corvette master cyclinder, should bolt up fine. friend of mine used one in a 62 impala worked great
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | Looking at the Raybestos site, I found a master cylinder for a 1972 C20 (3/4 ton), it mentions its outlet size is 9/16". Wonder if that is the same with yours if you had to use bigger lines or is it just the fitting that is bigger and you would use the stock size with your cylinder. I would guess that for a 3/4 it would be a bigger bore as well?
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | Just to mention again that if you visit the Raybestos site you can go through all the years for cars and trucks and look at their selection. I like the idea of going to the cylinder used for the 3/4 ton C20 truck the model is MC39075, not sure if bigger lines are required as they mention the outlet size being 9/16in X 18.
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | If I upgrade to a dual reservoir Master cylinder, will I need a proportioning valve? I figure I'll run a line for the front brakes on 1 port and rear brakes on the other port. | | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | I don't have a proportioning valve and the trucks stops fine. I don't think you need one for a drum drum set up. It's more of an issue if running a disc drum set up.
| | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | So I've bolted on the new adapter bracket and dual res master cylinder. When I try to bolt the new eye bolt/push rod to the brake lever arm, it doesn't line up. Seems like the MC is 1/2" too low. Also seems like the push rod going into the MC is too long. Anyone have any problems like this? The master cylinder has a ring holding the main bore plunger in place. I assume the plunger will move deeper into the bore once I remove the ring? That would allow the new push rod to go into it more. See pic below: http://s1107.photobucket.com/albums/h394/52ChevyProject/?action=view¤t=AdapterBracket.jpg | | |
