4 members (68ironhead, Bill Hanlon, Otto Skorzeny, Ranger), 112 guests, and 2 robots.
Topics128,032
Posts1,055,517
Members48,425
#796351 11/09/2011 4:29 AM
Hey guys,
I had a lifter bore dingle berry hone that i have had for a while. Now I can't remember who borrowed it and no one will fess up. I'm having trouble finding a new one. NAPA and Summit just say use a brake cylinder hone. I could, but I liked the ball hone. Looking for a supplier. Any help is welcome.
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!"
Elanor Roosevelt
1966 c-10 stepside
1966 c-10 fleetside
1964 c-10 fleetside
1964 c-10 short bed
1964 c-30 flat bed
1964 c-60 dump truck
1968 Impala
1969 Nova
1971 Nova
1975 LUV
1976 C-30
1977 K-20
1966 SS El Camino
David13 #796384 11/09/2011 7:04 AM
Dingleberry hones are still around. They are more properly called Flexhones. http://www.brushresearch.com/product-line.php?line=1
Not knowing your situation, I just gotta ask this. Why would you need to hone the lifter
bore??? That’s very unusual, valve lifters are fit up with a very tight tolerance, down in
the tenths of a thousandth generally. Unless they have been run dry this is one of the last
places for wear to turn up in an engine. God knows I haven’t seen everything but I sold
auto parts in a past life and I never sold an over size lifter for a gas engine.
If your lifters are tight 99.9% of the time it’s just varnish and can be cleaned up with
carburetor cleaner or something similar and a fine Scotch Brite (gray) pad. If your bore is
rally gummed up and you really need to be aggressive, you can slit a wooden dowel and
use a strip of Scotch Brite driven by your trusty Milwaukee drill motor. If for some reason
the bore got scored up then you could also use the dowel with a fine grit emery cloth and
a light oil such as kerosene or fuel oil.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Oversize lifters were available yrs ago for worn block bores.Sunnen does make a hone to straighten the bore. Typically, about a 1/2 to one thou is all you want, otherwise you'll hear them click,rattle, especially at idle. David
when i did mine i just used a plummers pipe brush with carb cleaner. came out rifle barrel clean.
Moderated by  MNSmith
