| | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 78 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 78 | Hey guys,
I had a lifter bore dingle berry hone that i have had for a while. Now I can't remember who borrowed it and no one will fess up. I'm having trouble finding a new one. NAPA and Summit just say use a brake cylinder hone. I could, but I liked the ball hone. Looking for a supplier. Any help is welcome.
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" Elanor Roosevelt
1966 c-10 stepside 1966 c-10 fleetside 1964 c-10 fleetside 1964 c-10 short bed 1964 c-30 flat bed 1964 c-60 dump truck 1968 Impala 1969 Nova 1971 Nova 1975 LUV 1976 C-30 1977 K-20 1966 SS El Camino
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not knowing your situation, I just gotta ask this. Why would you need to hone the lifter bore??? That’s very unusual, valve lifters are fit up with a very tight tolerance, down in the tenths of a thousandth generally. Unless they have been run dry this is one of the last places for wear to turn up in an engine. God knows I haven’t seen everything but I sold auto parts in a past life and I never sold an over size lifter for a gas engine. If your lifters are tight 99.9% of the time it’s just varnish and can be cleaned up with carburetor cleaner or something similar and a fine Scotch Brite (gray) pad. If your bore is rally gummed up and you really need to be aggressive, you can slit a wooden dowel and use a strip of Scotch Brite driven by your trusty Milwaukee drill motor. If for some reason the bore got scored up then you could also use the dowel with a fine grit emery cloth and a light oil such as kerosene or fuel oil. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 46 | Oversize lifters were available yrs ago for worn block bores.Sunnen does make a hone to straighten the bore. Typically, about a 1/2 to one thou is all you want, otherwise you'll hear them click,rattle, especially at idle. David | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | when i did mine i just used a plummers pipe brush with carb cleaner. came out rifle barrel clean. | | |
