2 members (Jon G, klhansen), 154 guests, and 4 robots.
Topics128,196
Posts1,057,396
Members48,469
I picked up a decent '52 GMC 1 ton eariler this year. King Pins wobble like a new sailor at 4 am on his first shore leave in Thailand.
With Christmas behind me, time to tinker.
I suspect these are a pain to remove and may well use a local machine shop to perform the work.
Where can i source a set of king pins?
What caveats do i need to be aware of? I suspect - these need to be reamed. Spindles look decent.
I looked over links on stovebolt.com but vendors are wide and varied as to what they may actually carry for the GMC 1 ton's. 1/2 or 3/4 ton stuff galore but seems limited for 1 ton trucks.
Rob in San Diego.
'50 Chevy 1 ton dually daily driver, 1960 Ford F-100, 1972 GMC C-20, 1958 Kenworth, Cat D4, 1972 Ford F100 Ranger
My machine shop can source parts but I would think FLAPS would have them. The bushings press in and they have to be reamed.
1951 1 Ton Completed
Who is FLAPS?
I just replaced mine from a FLAPS (friendly local auto parts store) here in Rapid City. Then took the spindles and pins to a local alignment shop to have them matched to each other.
Bruce
My Trucks
Stuff I Collect
Flaps did not see that coming.
If you're out in the boonies Carter's has a pretty good selection of king pins for the 1-ton.
Rockauto.com has 1952 GMC 250 king pin sets in standard diameter, and .010 over and .020 over sized diameter.
http://www.rockauto.com/catalog/raframecatalog.php?carcode=1487482&parttype=7340
Moderated by  Dusty53
