7 members (WICruiser, NJC, 3B, Greg_H, Steveoreno, Phak1, 1 invisible),
170
Mod | | | Forums66 Topics128,275 Posts1,058,574 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 42 | I picked up a decent '52 GMC 1 ton eariler this year. King Pins wobble like a new sailor at 4 am on his first shore leave in Thailand.
With Christmas behind me, time to tinker. I suspect these are a pain to remove and may well use a local machine shop to perform the work.
Where can i source a set of king pins?
What caveats do i need to be aware of? I suspect - these need to be reamed. Spindles look decent.
I looked over links on stovebolt.com but vendors are wide and varied as to what they may actually carry for the GMC 1 ton's. 1/2 or 3/4 ton stuff galore but seems limited for 1 ton trucks.
Thanks, Rob in San Diego.
'50 Chevy 1 ton dually daily driver, 1960 Ford F-100, 1972 GMC C-20, 1958 Kenworth, Cat D4, 1972 Ford F100 Ranger
| | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | My machine shop can source parts but I would think FLAPS would have them. The bushings press in and they have to be reamed. | | | | | Joined: Oct 2002 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 42 |
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I just replaced mine from a FLAPS (friendly local auto parts store) here in Rapid City. Then took the spindles and pins to a local alignment shop to have them matched to each other.
Bruce | | | | | Joined: Mar 2009 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 51 | Flaps did not see that coming. | | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | If you're out in the boonies Carter's has a pretty good selection of king pins for the 1-ton. | | |
