| | | Forums66 Topics128,131 Posts1,056,369 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 22 New Guy | | New Guy Joined: Apr 2010 Posts: 22 | my 3 on the tree shift lever broke off the other day. I did a temp repair with some metal & duct tape but would like to replace it. Can't find one anywhere. Do I need to replace the whole shift linkage? Any suggestions on where to get what I need?
Thanks for any ideas. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The lever is held on by spring loaded pins. New springs and pins are available from Jim Carter for sure and probably several others. | | | | | Joined: Apr 2010 Posts: 22 New Guy | | New Guy Joined: Apr 2010 Posts: 22 | I need the actual shift lever. It broke in the middle. | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | On ebay there is a junk yard selling off old truck parts. They would probably have one. Jim Carter truck sells some used parts, he would likely have one. | | |
