3 members (baldeagle, Hotrod Lincoln, Stovebolt48), 61 guests, and 5 robots.
Topics128,018
Posts1,055,339
Members48,419
#814557 01/08/2012 8:34 PM
Hey all. I'm setting the timing on my 54 235 6cyl. I have an HEI distributor in the old girl. I'm reading anywhere from 2-10 degrees. I set it at 10 this morning but I'm getting some back fire through the exhaust. Thank you
bgd54 #814658 01/09/2012 2:25 AM
poke a screwdriver down cyl #1 and check that your timing marks are within a mile.
If you have a vacuum gauge, set it for max vacuum at idle.
check that your centrifugal bobweights are OK.
Was it OK before you fiddled with it?
The rotor may be dodgy. HEI units demand better insulation due to higher firepower.
If all else fails, retard it and hold the idle slightly high, then rotate the dizzy fowards and find the spot that gives the greatest increase in idle speed for movement of the dizzy. This will be where its passing over TDC. that will get you moving.
A neon timing light or triggered timing light may show erratic or intermittent timing- then something is wrong.
cheers
Rich
'47 Canadian RHD 1.5 ton truck
anyoldiron #814801 01/09/2012 4:28 PM
Hi bgd54,
Did you pull the distributor out and then install the modified one? Maybe you have it 180 out ???
