Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (klhansen, jmoore, jay d), 126 guests, and 3 robots.
Topics128,288
Posts1,058,577
Members48,492
#814591 01/08/2012 11:05 PM
Is there a difference between the 216 and the 235 distributor?
Dennis
oldbluetruck #814600 01/08/2012 11:38 PM
ODSS Lawman
ODSS Lawman
Nothing
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #814604 01/08/2012 11:58 PM
The short answer is yes. If you look in the parts books just up through 1954 you'll find about 8 different part numbers. I think the differences mainly in the advance curves and vacuum advance mechanisms and many of these will interchange.
But, there is a major difference between the '54 powerglide cars and all later 235's compared with the earlier 216's and that is the composition of the drive gear. The later engines use a cast-iron alloy gear while all the 216's used a forged steel gear. You can use any of the later gears on an earlier engine but the forged gear from an earlier engine will eat the cam gear on the later engines.
This is easy to fix though by just changing the distributor gear to match the cam.
waldo53 #814656 01/09/2012 2:16 AM
Thanks. I have a good 216 distributor and hope to get a rebuilt a 235
Dennis
oldbluetruck #814701 01/09/2012 5:01 AM
1953-62 235 distributors use a taller cap and rotor than a 1937-53 216 or 1941-52 235.
My Blog
Pre '68 Dave #814852 01/09/2012 7:01 PM
Can I use the distributor and use the taller cap and rotor for a 58-62 235?
Dennis
oldbluetruck #814873 01/09/2012 8:15 PM
The 216 style shaft is to short to correctly hold the rotor.
My Blog
Pre '68 Dave #815019 01/10/2012 3:24 AM
So. What is the difference between the rotors and caps?
Dennis
oldbluetruck #815024 01/10/2012 3:28 AM
tclederman #815124 01/10/2012 3:50 PM
Will the 47-52 distributor work like the 53-62 distributor on a 235? If not, I think I have a 53-62 distributor. But it is nasty and needs a good clean job. Or just change out the shaft?
TIA
Dennis
